Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Questions View all
No power, not recognized by computer, HELP
I bought this used iPhone 7 Plus second hand.
Owner said it just stopped turning on and was okay with it.
I thought it would be an easy fix.
After plugging it in to charge, it never turned on.
Same with the computer, it did not detected it.
I ordered a charger port replacement from alibaba, replaced it and connected it. NOTHING. No charge, not recognized by computer.
So, I ordered a replacement battery on ebay and still no success.
No sound, image or vibration.
Any suggestions what might be the problem?
Thank You!
- The phone most likely was dropped at some point? No water damage.
1 Comment
I phone 7 plus broken screen and will not turn on at all
by
Add a comment
Chosen Solution
Usually when the phone does not turn on, battery is the least likely cause since the battery almost never fails completely.
This is NOT an easy fix. Anything could go wrong with your phone, and since it does not turn on, you know nothing about the real nature of the problem, it could range from easy to nightmare. Naively thinking the problem must lie at the easy end will cost you big time.
Either return the phone or suck it up as a life lesson, or pay premium for board level repairs.
Score 3
3 Comments:
For $85, it was tempting.
Having done past repairs, I did not expected that huge of a problem.
by
Well you can't blindly trust second hand products, they won't tell you what they've been through. Also do not trust products recently hit the market. Xbox 360 and Galaxy note 7 are examples.
by
That was only $85? I would have bought that in a heartbeat!
by
Add a comment
Might be a motherboard issue, you could go in and check all the flexes, reseat them. If there are any signs of physical damage, like a bend? that could pretty much tell you if something broke.
1 Comment:
I did not found anything unordinary, the motherboard was intact and so was the glue for the water resistance. Will have to retake it apart.
by
Add a comment
Add your answer
Daniel Gonzalez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 327
