The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
MacBook won't start up and just makes a CD spinning sound
I dropped water on the side of my MacBook but it was shut. It worked for a few hours but when I put it to sleep and later open it again it was shut off, but after a few tries it worked. However the next day I tried to start it up and it would no longer start up. After trying to turn it on many times now I can hear it making a sound that is similar to that of a spinning CD and it's slightly warm on the bottom. However the screen is still black and there was no startup chime. It has been a few hours and the laptop is still making that sound but nothing has happened. Does anyone know what I could do?
Score 1
Add a comment
1 Answer
Most Helpful Answer
What to do when you spill liquid on your Macbook Pro.
Follow these 3 simple steps after a liquid spill on your MacBook Pro
Power the MacBook down – Shut off the MacBook as soon as you discover that it has been exposed to liquid! The majority of spills occur when the MacBook is powered on and in use, so you must fight the urge to dry it off and continue working. Do not tilt or roll your MacBook while to get the liquid out while the unit is powered on.
Unplug any accessories – This one is important, some devices send electrical current back to the Logic Board thus causing more damage. Additionally having any hole available so the the liquid can escape from is always a plus.
Dry off any and all external liquid – While it will be nearly impossible for you to dry off any of the internal components so make sure you dry of the outside of your MacBook carefully. When drying of the outer parts of your MacBook, avoid rolling the MacBook around, doing so only cause the liquid to pitch and roll throughout the unit unnecessarily exposing more internal components to the liquid. Finally carefully flip the unit over keyboard side down and allow gravity handle the rest. This will direct the liquid away from the main logic board.
Putting your MacBook in rice may give you a false sense of security. Putting your in rice after MacBook water damage has occurred is said (wish I knew said this nonsense) to dry up the water and prevent any additional damage. Rice does not benefit a water damaged MacBook in any way. My guess is that this was a tactic used service providers to deter people from attempting to power on the device after the spill, if your Mac is in a big bag of rice then your not trying to power it on. we all know that it takes every ounce of self control not try to power your Mac on every hour to see if it has come back to life. Remember trying to power on the Mac after the spill is a big NO NO!
Score 1
1 Comment:
I think it comes from seeing rice in salt shakers. People assume it is there to absorb moisture. Actually it helps beak up salt clumps.
Electronics Water Damage
by
Add a comment
Add your answer
karamba08 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 149
