The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
170 Questions View all
will motherboard replacement work
HI,
recently my Note 5 has been water damaged and our local repairers have advised it can not be fixed thus if i happen to change the motherboard, it will work right?
and is this what i need to replace or are there other things as well.
https://www.aliexpress.com/item/100-Orig...
Its been 2months now and still unable to switch on and also when i try to charge it starts heatings.
Please advise
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
@avilal , Avi Lal , There could be possibly more damage to Note 5 then just the mother board, display, battery,etc.(unless tested to be good), liquid can play havoc on electrical components shorting them out. As far as the MB at the link, it appears to be correct, but always verify the part is correct to your devices model # from the seller before ordering. Good luck.
Score 3
Comments:
Add a comment
Add your answer
Avi Lal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 61
