Released in November 2012, the GoPro Hero3 is a Wi-Fi capable, 4K resolution digital camcorder.
101 Questions View all
How can I get wifi password?
I order GoPro Hero3 Black Full Assembly and I received.
And I try connect to wifi, but I cannot.
because I don't know password.
Score 1
Add a comment
Chosen Solution
1.Connect your GoPro to your computer. (Alternatively, you can also just insert your
microSD card using an SD card adapter)
2.Download the file from the link at the bottom of this post
3.Extract the zipped folder
4.Copy the contents of the folder and paste its content to the root folder of your GoPro’s microSD card.
5.Paste the whole “UPDATE” folder to your GoPro’s root folder. The files must be in a folder with the name “UPDATE”, otherwise it won’t work.
6.Unplug your GoPro. It should automatically turn off.
7.Turn it back on. Your GoPro should display now that it’s updating. Once it’s done it will turn off again.
8.You can turn it back on now and connect to its WiFi network with your device using the default login:
Network name (SSID): GoProHero
Network password: goprohero
Download link, replace the $ with a period after net because otherwise it'll delete my answer http://trendblog$net/download/files/GoPro_Hero3+_Black_WiFi_Reset.zip
Comments:
Thank you your help.
I did it the way you told, but I fail.
But I found the way at the site you mentioned and I Success.
My Gopro type hero3, (not hero3+).
That's just the reason. ^^
Thank you!!!
by
Glad I could help @bbogle ! Please vote up my answer and mark this as solved. :)
by
Add a comment
The default password I believe is "goprohero".
Otherwise,
1. Connect your GoPro to your computer. (Alternatively, you can also just insert your microSD card using an SD card adapter)
2. Download this file
2.5. Gopro update
3. Extract the zipped folder
4. Copy the contents of the folder and paste its content to the root folder of your GoPro’s microSD card.
5. Paste the whole “UPDATE” folder to your GoPro’s root folder. The files must be in a folder with the name “UPDATE”, otherwise it won’t work.
6. Unplug your GoPro. It should automatically turn off.
7. Turn it back on. Your GoPro should display now that it’s updating. Once it’s done it will turn off again.
Conclusion You can turn it back on now and connect to its WiFi network with your device using the default login:
''Network name (SSID): GoProHero
Network password: goprohero''
Add a comment
Try using the password goprohero as that should be the default.
Otherwise;
  2. Download Gopro hero 3+
#Extract the zipped folder
#Copy the contents of the folder and paste its content to the root folder of your GoPro’s microSD card.
#Paste the whole “UPDATE” folder to your GoPro’s root folder. The files must be in a folder with the name “UPDATE”, otherwise it won’t work.
#Turn it back on. Your GoPro should display now that it’s updating. Once it’s done it will turn off again.
#You can turn it back on now and connect to its WiFi network with your device using the default login:
Add a comment
Try using goprohero as this should be the default password.
Update (02/14/2017)
Download link http://trendblog.net/download/files/GoPr...
Comments:
I tried, but password is not correct
by
Add a comment
2.This is the link for an update that will help you change the password. Follow the next few instructions to do this correctly.
Add a comment
Download link, copy and paste into your browser. trendblog.net/download/files/GoPro_Hero3+_Black_WiFi_Reset.zip
Add a comment
Since we know that Google is quite famous for its standalone messaging apps including Hangouts, Voice, Allo and Android Messagesetc. Still there are chances that Google was not feeling satisfactory as compare to its competitors which already has introduced several apps like iMessage, Facebook’s Messenger and Whatsapp.
Add a comment
Add your answer
KIMBOGEUN will be eternally grateful.
Past 24 Hours: 23
Past 7 Days: 146
Past 30 Days: 581
All Time: 2,199
