Phone call speaker/voice thing won't work...
When I make a phone call or someone calls me, I have to have it on speaker or they can't hear me. Please help.
Add a comment
1 Answer
Chosen Solution
Hi,
Try using the earphones with the microphone attachment and make or receive a call.
If you can now be heard properly then there is a problem with the phone's microphone. It may be faulty, loose on the systemboard or the voice "inlet hole" on the bottom of the phone may have become blocked with lint etc.
To check the last possibility, use a strong light and a magnifying glass to see if the hole appears blocked. If it does DO NOT try and clear it using a pin or probe as the microphone is directly behind it and you may damage it. Try a vacuum cleaner using short sharp bursts to see if this clears the obstruction.
Score 2
Add a comment
Add your answer
Alexis Wade will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 60
All Time: 216
