Repair and disassembly guides for Kenmore Microwaves.
126 Questions View all
Replace door latch assembly
How do I disassemble the door to replace the latch and spring assembly?
Microwave #721.85033010
Comments:
I had found that previously but it doesn't really show how to disassemble the door.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I would strongly suggest to order the complete door. The door is easy to replace, just lift up.
There is a risk of microwaves leaking after the door is dissasymbled A survey test is required after repairing a door. If you don't own a survey meter and aren't qualified to use one, then order a door.
Score 2
Add a comment
Most Helpful Answer
jason haddad , The link below will show the break down of parts on the door assy. I my self do not condone inexperienced persons working on Microwaves as they are one of the most dangerous appliances to work on and take considerable knowledge in most repairs to prevent harm to persons and device. Good luck.
http://www.searspartsdirect.com/model-nu...
Score 2
Add a comment
Add your answer
jason haddad will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 124
All Time: 849
