Eleventh generation of Ford's flagship pickup truck.
22 Questions View all
Why does seat belt not latch?
Seat belt won't latch
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
@bigredd , Todd Rediger, If you do not see any obvious obstruction inside the buckle that you can picked or blown out and the opposite (latch) end is straight/undamaged, it is recommended to replace the defective part for safety. The buckle lock tab/spring could be worn/damaged inside and are not meant to be serviceable. You could order a new replacement or check out the local auto recycler for the part as it would be low cost from them. Video link below may be of some help with belt replacement or if not wanting to do repair yourself, take into a good shop, have them take a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=IgwfQZsE...
Score 3
Add a comment
You need to give more details
1. Check if there is anything blocking the "receptor".
2. Check if any parts are broken
Add a comment
Add your answer
Todd Rediger will be eternally grateful.
Past 24 Hours: 16
Past 7 Days: 93
Past 30 Days: 419
All Time: 1,309
