I have 2 of these with broken record buttons; any way to repair them?
I have 2 of these mini disk recorders and love them but both now have a broken record button. Can they be fixed? if so where or where can i get parts for them?
Button is recessed in the unit where it normally would set up and have to be depressed to be engaged.
Add a comment
1 Answer
Chosen Solution
Hi
Here is a link to the service manual for your recorder. This will help to disassemble the recorder to gain access to the switch to ascertain the problem.
https://www.manualslib.com/manual/781184...
If it is the switch itself that is the problem then here is the part number for the record button (I think,1-572-922-11, found on p.51 of the manual).
Here is a link to just one supplier of the part. It is not a recommendation to use them merely to give an idea of the price. There are others online just search using the part number only to get results. Scroll down about halfway to find the part.
58728 SON CC REC/PB SW 1-572-922-11 ANDREWS ELECTRONICS -1505 $4.50
http://mikescamera.com/andrews-electroni...
Hopefully this is of some help.
Score 2
Add a comment
Add your answer
Steve Sturm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 114
