Why cant people hear me on the other end of calls
Since I've had my phone whenever I try to call or video chat someone I can hear them but they can't hear me. I've reset the phone and it still won't work.
Hi,
Try using the earphones with the microphone attachment and make or receive a call.
If you still cannot be heard properly then there is a problem with the voice transmission circuit in the phone.
If this is the case, if the phone is relatively new, (you do not say or state the model number) verify the purchase date and then consult the warranty statement that came with the phone's documentation and if it is still within the manufacturer's warranty period follow the instructions as to what to do to make a claim for a warranty replacement.
If you can now be heard properly then there is a problem with the phone's microphone. It may be faulty, loose on the systemboard or the voice "inlet hole" on the bottom of the phone may have become blocked with lint etc.
To check the last possibility, use a strong light and a magnifying glass to see if the hole appears blocked. If it does DO NOT try and clear it using a pin or probe as the microphone is directly behind it and you may damage it. Try a vacuum cleaner using short sharp bursts to see if this clears the obstruction.
If it doesn't appear to be blocked then see warranty claim above.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,076
