Which adhesive to use?
Can anyone tell me which adhesive is best to use for sticking down flex cables, home button gasket, rear camera plastic surround etc?
Thanks in advance!! :-)
Use the same home button gasket replacements if you want the home buttons to stay in place well without wobble or rotating.
For the flex cables I recommend thin double sided tape. Probably Tesa 61395 is suitable.
Thanks Ben.
Sometimes the gasket loses its stickiness so could do with a little more adhesive.
You can apply heat (I use heatgun on 80°C 15 seconds average) to reuse old rubber gaskets.
I do use double sided tape similar to Tesa 61395 if I don't have replacement rubber gaskets available.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 103
