charging socket not working in my pill how I can fix it?
In my pill charging socket not worked when push very well then start charging and not cahrged well so how can i fix it my speaker
Hi,
Use a strong light and a magnifying glass to check that the socket is clean and that there is no lint trapped in there
If there is DO NOT try and use a metal probe to remove it as you may damage the pins. Use a vacuum cleaner to try and remove it. If this doesn't work then try a wooden toothpick to gently (stress gently) try to clean it out.
Also check that the pins are all straight and parallel with each other and are all the same.
If the charge port is clean perhaps the charge port is loose on the systemboard.
You mentioned in the title of your question that it is a New pill xl bluetooth speaker model WM-1300. How long have you had it?
Check the warranty statement in the User Guide that came with the speaker to see what the warranty period is. Check and verify the purchase date on the sales receipt of the speaker and if it is still within the warranty period, consult the warranty statement as to what you have to do to make a claim for a warranty repair or replacement.
If it is no longer in warranty, the speaker will have to be opened and the problem diagnosed as to what needs to be done to resolve it.
Hopefully this is of some help.
But how it open i can't find any lock or screw in speaker
Hi, I am not saying to open it up I am saying to look into the USB charge port from the outside. What you can see without the cable being plugged in. Use a strong light and a magnifying glass to see better. Check that all the pins are there and that there is no lint or dirt etc.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,625
