The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Questions View all
Touchscreen was unresponsive randomly at times, before it got wet...
...So recently i dropped my note 5 in some water but the ldi is white according to the one in the sim tray. I wanted to turn it in for warranty but I'm afraid I will get charged for water damage if there was even another LDI underneath the case (possibly under the motherboard so it wouldnt be tampered with) and I was wondering if I could just fix the whole touchscreen problem itself rather than paying $230+. Before I dropped it in water, the screen was unresponsive to touch and glitched many times. Some areas were unresponsive, such as the corners. After the water incident, touch was unresponsive to the whole screen, only the s-pen worked. Everything works perfectly fine, sound, screen, camera, battery, everything, but just touchscreen. The screen itself is dry and has no water blotches underneath.
Update (02/11/2017)
I've also rebooted my phone plenty times before the incident in case it was just a hardware problem. Done factory reset 50000x and I'm pretty sure the phone itself got frustrated that it locked itself in safe mode for a couple hours before I took control again. I'm quite dissapointed in myself for not getting an exchange before having that incident or else I wouldn't have to deal with this issue.
Add a comment
1 Answer
Chosen Solution
Odette “the” Odish , You may have to take your device apart and treat it/clean from liquid damage/corrosion. Below I will post a general guide(link #1) telling how to clean the device of liquid/corrosion. Link #2,#3 show how to take the device apart to access internals to clean and 4th link is where you can select your phone and select a replacement screen assy. if need be. Good luck.
Electronics Water Damage
Samsung Galaxy Note5 LCD screen & USB board & Home button Replacement
Samsung Galaxy Note5 Teardown
[[ invalid parts link ]]
Samsung Galaxy Note5 Image
Guide
Difficulty:
Moderate
Samsung Galaxy Note5 LCD screen & USB board & Home button Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 3
Add a comment
Add your answer
Odette “the” Odish will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 748
