Why won't microphone support screw bite?
On my wife's iPhone6, I was inspecting the bottom microphone. Basically the bottom mic stopped working to pick up speech. it would pick up blowing directly on it but not speech. Anyway I decided to remove the pentalobe screws, open the phone and then remove the microphone support so I could inspect the microphone hole. The phone was repaired once by a local shop before. The microphone support screw came out normally but when I went to replace it, the screw would not bite into the bottom board. I assume all these little Phillips 00 are the same diameter just different lengths. I'm guessing the last go round they might have stripped the socket threads? Any suggestions on getting the screw to set again?
