Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Questions View all
Replacement airport card (BCM94331PCIEBT4CAX) will not turn ON
The Airport card in my Macbook has become intermittent so I ordered and fitted a replacement, BCM94331PCIEBT4CAX.
When the MacBook powers up the WiFi status indicates WiFi is OFF, attempting to turn it on silently fails.
System Report -> Network -> WiFi lists the Airport card, with status OFF.
The only difference between the listings for original and replacement Airport cards are :
Locale FCC (orig) / RoW (replacement)
Country Code XO (orig) / GB (replacement)
My MacBook was purchased in the US, the replacement AirPort card was bought in the UK, where I'm located.
The wifi log file shows the following :-
Sun Jan 29 00:08:18.203 <kernel> AirPort_Brcm43xx::platformWoWEnable: WWEN[disable]
Sun Jan 29 00:08:46.363 <kernel> wl0: powerChange: *** BONJOUR/MDNS OFFLOADS ARE NOT RUNNING.
Sun Jan 29 17:12:19.996 Starting Up
Sun Jan 29 17:12:21.084 <kernel> Unable to create IO80211InterfaceMonitor
Sun Jan 29 17:12:21.084 <airportd[69]> airportdProcessDLILEvent: en1 attached (up)
Sun Jan 29 17:12:21.092 <kernel> Setting BTCoex Profile: band:8
Sun Jan 29 17:12:21.092 <kernel> Profile[0]: mode:7; desense:0; desense_level:0; chain_power_offset:<kernel> 0,<kernel> 0,<kernel> 0,<kernel> 0,<kernel>
Sun Jan 29 17:12:21.092 <kernel> Profile[1]: mode:7; desense:0; desense_level:0; chain_power_offset:<kernel> 0,<kernel> 0,<kernel> 0,<kernel> 0,<kernel>
Sun Jan 29 17:12:21.092 <kernel> Profile[2]: mode:7; desense:0; desense_level:0; chain_power_offset:<kernel> 0,<kernel> 0,<kernel> 0,<kernel> 0,<kernel>
Sun Jan 29 17:12:21.092 <kernel> Setting BTCoex Profile: band:2
Sun Jan 29 17:12:21.093 <kernel> Profile[0]: mode:0; desense:0; desense_level:0; chain_power_offset:<kernel> 0,<kernel> 0,<kernel> 0,<kernel> 0,<kernel>
Sun Jan 29 17:12:21.093 <kernel> Setting BTCoex Config: enable_2G:1, profile_2g:0, enable_5G:1, profile_5G:0
Sun Jan 29 17:12:21.205 <airportd[69]> _bsd_80211_event_callback: Failed to get power setting from device : err -3900
I checked and recheck installation and eventually refitted original AirPort card, which worked, but only for a while as it's become intermittent.
I'd appreciate and insight into how I can fix this issue.
Thanks.
Add a comment
1 Answer
Chosen Solution
I'd give a try in reinstalling the Os if I was you. I imagine you have already tried a Pram reset. Be aware that the wifi module reinitializes when you turn off the mac, as a reboot by itself is insufficient.
Score 3
3 Comments:
No, I've not tried Pram reset, didn't know of it.
I will refit the replacement AirPort card and give pram reset a try.
I'll feed back the results on this thread.
Good point about the wifi module only reinitialising following power off, I did try power off, the problem remained.
Thank you.
by
Excellent, after resetting the PRAM, the replacement AirPort card just works.
Thank you very much Arbaman.
by
You're most welcome..glad I could help :)
by
Add a comment
Add your answer
Paul Wilkinson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 987
