Fix Your Stuff
Right to Repair
Store
Portable wireless speakers from Logitech released in 2013.
68 Questions View all
Battery dying very quickly!
I got the UE boom 2 for Christmas and its suppose to last a decent amount of time...like 12 hours or so. I understand at high volunes this time goes down but mine is lasting maybe 2 hours or so and i already sent one back because of this but having the same problem with the 2nd one!!!! I charge it at night while i am sleeping, is that the problem? Am i over charging it??
Score 7
Comments:
The battery barely gets out of warranty and doesn't charge and there is no battery replacement anywhere. In the garbage with it. What kind of company makes a product the doesn't support battery replacement?
by
The battery for my UE Boom2 is replaceable. The manual that comes with the speaker shows you step-by-step how to open the device and replace the battery. The instructions are in both English and French. The battery can be ordered from Amazon.
by
Add a comment
STUDY UNPLUGGED
Battery Fix Kits for Mac
Shop Fix Kits
STUDY UNPLUGGED
Shop Fix Kits
Most Helpful Answer
@arossi143 , Alise Rossi , when you sent back the 1st UE boom 2 did you also send the charger, if still using the original charger from 1st boom, this could be the issue faulty charger, try a different charge method perhaps. UE says that you'll get 15 hours of battery life from the Boom 2, from a 2.5-hour charge through that micro USB port with the bundled 10-Watt USB wall charger and flat cable. Maybe you are overcharging by leaning plugged in 12 hours, so try the 2.5-3 hour charge a few times to see if it makes any difference. Also try turning(reducing) volume to say a third and see if it last longer, some forums state the battery performance greatly reduce when volume on in higher range.
There are two ways to check your speaker’s current battery level. Button press, Press your speaker’s ‘plus’ and ‘minus’ buttons at the same time. An audio message will play telling you the current battery level.
Open the UE BOOM app.Tap the +/- area on the UE BOOM on the home screen to display the battery life while your speaker is on.
If your battery level are showing full and speaker is not living up to your expectations return under warranty for repair/replacement/refund. Good luck.
Score 5
Add a comment
Had a similar problem with my 1st gen UE Boom. Was researching battery swap but stumbled across a reset option.
With the unit off, hold the Vol down button and the main power button for 20 seconds (well, that’s how long I did) to reset the device.
Will have to re-pair it with devices (and rename it via the app if you like) but after the reset, it took about 3 hours for a full charge and battery life appears to be MUCH improved. Cost’s nothing and worth a shot…
Score 2
Add a comment
No! UE simply sucks. I’m switching back to bose! More expensive but you get what you pay for!! Listening to music for only two hours over the speaker is unacceptable. My iPhone has a better life charge. And if you have the cord directly in the outlet, it still dies!!! WTF!
Comments:
I have this box for more than a year, everyday use cus of work and still deff 10 hrs batt time
by
Add a comment
me i have the same problem now with the Ultimate Ears Megaboom 3. When i got it for Christmas the battery have fonction for 22 hours and more days past more my battery life die fast (I charge it just when the battery are at minimum and I stop the charge when he have 100%) Sorry if my text its not good but my true language its the french
Add a comment
I got bought a ur mega boom a year ago and the battery is not keeping charge at all can some help or give any advice on this thank lj
Comments:
Original UE Boom is a heap of rubbish. Considering the price of these things any product where the battery dies and cannot be easily replaced is a lemon. I have no problem with other (Computer) equipment from Logitech but am very disappointed with the UE Boom.
by
Add a comment
It’s not worth the money by a long shot. I’ve had mine replaced with a new charger and it made no difference. It’s well made in my opinion but the battery life is it achilles’ heel. It says it can last up to 12 hours but that’s on low volume. Heck I just used mine which the app said it was at 70% and 30 mins later it’s dead. Waste of money, go with Bose. Everyone should get a refund for false advertising.
Comments:
I've just brought a UE Boom 3, on full volume I get 2hrs out of the battery, on half volume around 4hrs. Either it's a faulty battery or some very good SEO work because there 16hrs of play time thats just not there. Taking it back to the shop on Monday.
by
Add a comment
Add your answer
Alise Rossi will be eternally grateful.
Past 24 Hours: 24
Past 7 Days: 167
Past 30 Days: 784
All Time: 42,534
