Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Questions View all
USB Power issue: one port (semi) works, other is dead
On a mid-2012 MacBook Pro 15" Unibody (820-3330 logic board):
This issue seems to have started after using the USB ports to charge R/C aircraft. I've tried SMC and PRAM reset, unplugging the internal battery, but no change.
The front port (closest to the SD slot) seems to be completely dead, and doesn't supply power to devices at all. Haven't checked with a powered hub yet, but I have a feeling that the data lines probably work fine.
The rear port (closest to Magsafe) works, but when I try to charge an iPhone, for example, it only works for a few seconds. I think it's requesting higher charge current, and then it cuts off. Other low-power USB devices seem to work fine on the rear port.
Looking at the schematic, it seems maybe U4600 is responsible for distributing the power to the two ports. I haven't tried any measurements yet, but wondering:
- is there a common failure point in this circuit? or...
- do these symptoms point to a specific component?
- any suggestions on where to start with measurements?
I have a friend who has equipment to handle surface mount soldering, once I can figure out the component(s) in need of replacement. Thanks in advance for any suggestions!
Score 1
Add a comment
Chosen Solution
Came back to report that after replacing the TI TPS2561 IC, I got 5V back on both USB ports, and they both work fine.
(like this guy: https://www.stohn.de/3d/index.php/20...k... )
Add a comment
Most Helpful Answer
To start with it sounds like your R/C model has a short within its power services which burnt the fuse link for the dead port.
You'll need to measure the voltage of the lines. I would get a device like this one to check things: Charge Doctor it makes quick work on not just testing your system but also the devices current draw.
Score 2
1 Comment:
Thanks for the suggestion for the testing device. Looks like a handy tool to have around!
by
Add a comment
Add your answer
Randy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 496
