printer says, print starting but won't print.
printer says print starting but won't print.
When you select printer make sure you go under name and choose the printer . Most times when it wont print the name is set on document writer or pdf printer. Other things to check for are . Is the paper in straight is there a paper jam ,do I have ink ,is the printer tray open . Is the printer turned on . Is your printer connected . Make sure theres nothing waiting in queue . Just some things to check . Hope this helps
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 30
