Stumped By iPhone 6 Reboot Loop (Tried Everything!)
Guys, I'm running into a problem with my iPhone and it seems like I've tried everything to no avail. Would really appreciate more troubleshooting ideas.
Phone Information
- Model: iPhone 6 (A1549) 64GB
- Carrier: Verizon
- Operating System: Latest iOS (no jailbreak)
- Age: 2 years
Problem Symptoms
- Press power button, Apple logo appears for a few seconds then screen goes black and the process restarts.
- If left alone, process will repeat for about 10 minutes before the cycle breaks and the screen stays dimly backlit for hours.
- After a few hours the dimly backlit screen will drain the battery and phone will shut off.
- Pressing power button now will show the dead battery screen indicating to plug phone in to recharge.
- Once plugged in, phone will recharge and boot back up to start the whole thing over again.
Problem Origin
- I broke screen a few weeks ago and replaced the LCD/Digitizer with a new one from Amazon.
- New screen seemed to be working perfectly fine for weeks.
- I noticed battery was draining faster after new screen installation and proximity sensor stopped working.
- Suspecting damage to the front camera assembly while switching it to new screen I ordered a new assembly from Amazon.
- Phone was working fine until this point; This is what I did the day my phone died:
- Turned phone off.
- Disconnected battery connecter.
- Disconnected screen.
- Switched out front camera assembly.
- Reversed process and powered up.
- Phone has been stuck in this reboot cycle since then.
Troubleshooting
- First thing I tried was simply going back with old camera assembly. That changed nothing; phone will power on, show log for a few seconds then restart.
- Tried starting with the camera assembly completely disconnected and nothing changed.
- Tried starting with nothing but LCD screen connected (no digitizer, no front assembly, no home button) and nothing changed.
- Disconnected battery and tried starting while plugged in to charger. Phone got stuck in reboot cycle again as if nothing changed with battery out.
- Let battery completely die until phone indicating that it needs to be plugged in to charge. Then I left it on the charger overnight. It recharged, powered back up and loop started again.
- Replaced battery with a new battery and nothing changed. Tried a third battery, nothing changed.
- Took phone apart down to logic board to see if I had accidentally disconnected something and brushed all connectors before I reassembled. No change.
- Updated iTunes then plugged in my phone to see if I can get a firmware update. As the process starts phone reboots and gets stuck in loop again. iTunes says I should do a restore.
- Tried manual firmware update by holding shift while clicking "Update" in iTunes and used the latest firmware file which I had already downloaded. As soon as update process starts phone reboots and gets stuck in loop again.
- Started restore process in iTunes acknowledging that it will wipe all my data. As soon as restore process starts phone reboots and gets stuck in loop again.
- I can put phone in DFU mode and then kick it out of DFU mode using Tenoshare's ReiBoot. I have not tried using ReiBoot pro which claims it can fix this issue but reviews looked shady.
- Swallowed pride and took phone in to a repair shop (not Apple Store). They said they have no new ideas beyond what I tried.
I am completely out of ideas. If you have any suggestions that may save my phone I would love to hear them; will ship beer to anywhere in the US for an idea that works!
4 Comments
For third party program other than iTunes. Use 3Utools. Thank me later as it's at least very useful when it comes to reading information of any iPhone battery with the health of it.
Also did you try the previous screen because a improperly detected screen causes the phone to boot loop like that.
Well I can only confirm if no screen is plugged into the phone it will turn on and off every few seconds when plugged into charger since the current draw from the phone alternates from 0 to around 1.6 amps.
by Ben
Thanks, Ben. I'll make sure to download that as soon as I get home. I was hoping to find a tool that gives more diagnostic information.
by Sam
Same thing with me. At last, I solved it by this method.
How to Solve iPhone Endless Reboot Loop
by Lira0
Hi all, this might not help with OP's problem, but may be helpful for people Googling the systems and trying to troubleshoot. I experienced these symptoms while testing out a replacement screen before fully re-assembling the phone. It was caused by forgetting to re-connect the battery. Sorry that the extensive list of things you've tried so far has not been fruitful OP, but you might want to test replacing the whole battery including the connector that goes on to the mainboard. Thanks
by derwentx
