TI-84 Plus calculator support.
13 Questions View all
TI 84 Calculator got wet from water. Won't turn on.
Changed batteries but won't turn on. What can I do?
Score 2
Add a comment
1 Answer
Chosen Solution
Try these steps...
  • Open your calculator and remove the logic board
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
Score 3
Add a comment
Add your answer
Mae will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 31
All Time: 1,255
