Leaking under the dispenser
My kenmore HE2 plus is leaking water from the bottom of the dispenser, only during fill up. I have cleaned the dispenser and checked the hose that connects to the tub. There are no obstructions. What else could it be?
5 Comments
@amelia1114 exactly where is it leaking from? "leaking water from the bottom of the dispenser" is a bit broad. Can you post a couple of images with your question? Use this guide Adding images to an existing question for that. It will allow us to see what you see.
by oldturkey03
Thank you for the image. Any chance you can post the model number as well. There are a few different HE2+ models.
by oldturkey03
110.47532601
Thank you
by Amy
@amelia1114 , Amy, that is leaking in the same location as the 1st video link I posted, looks like the top of washer will have to be removed and the detergent drawer to access the hoses, to check if they are plugged/damaged and are secured well(clamped). If not comfortable doing the repair yourself, have a good repair tech. have a look diagnose and estimate repair, does not look like more than 1 hour labor to unclog, unless drawer it self is cracked or hose damage which means additional $ for parts.
by L Pfaff
Water is coming through the dispenser while filling the front load washing machine
by Cecile Curtis
