error code 4SNS/1/40000000: TGOD
Hi, I have a simillar problem. When I run the AHT it "spits out" the error code 4SNS/1/40000000: TGOD but no numbers after it so I wonder what happened. My mac is also running fairly well, it doesn't shut down after some time. But when i even 1 app it goes into some kind of turbo mode and the metal (near the display) is really hot. So do you think I am worrying to much or should I check the cooler fans. Thanks for response, Josef.
2 Comments
Have you run disk utility to check the hard drive?
by S W
Check that the temperature sensor cables are attached as well.
by Amit Phillaura
