2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
changed the battery, says - cycles 0, replace now, fully charged
Hi
I have a problem with a new battery from eBay, that i put in a MacBook i just bought. Before I return it I want to check on this forum if there is anything I am missing. Status is:
- Can not run without power chord
- Battery percentage stuck at 97%, no discharge/charge
- Condition: replace now
- Says battery is charged, though light on chord is red
Battery info:
Can´t figure if its the battery or if its a possibility being a hardware issue. I just acquired it, and haven´t seen it function normally with a battery, as the previous one had the same behaviour, only it said 0% instead. Has anyone heard of this?
Thanks in advance
2 Comments
Have you reset the SMC and PRAM?
by
yes, tried SMC and pram reset. thank you
by
Add a comment
1 Answer
Chosen Solution
Try an SMC reset and NVRAM reset. If this doesn't work, you most likely have a bad battery.
Order another battery and try it out. If it is still doing this, it will be an issue with the battery sensing circuit, although I have not come across one which will cause it to say "replace now" if it is a good battery.
Score 2
3 Comments:
thanks for the response.
Ive tried resetting SMC and Nvram, but no change. That sounds good. Is the battery sensing circuit integrated to the logic board?
by
A lot of people mistaken the amber orange charging light on the magsafe charger as a red light.
It is most likely showing an amber light on the charger because if it was really red (flashing red) the Macbook would not receive power from the charger.
by
@big_bird yes, the battery sensing circuit is on the logic board. I think there is a control board in the battery which tells the Macbook the condition though (service battery, replace soon, replace now, etc), since I haven't come across a Macbook before which will say a good battery needs replacing, which ended up being a logic board fault.
by
Add a comment
Add your answer
Simen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,231
