Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1076 Questions View all
Can I use a home button from another iPhone 6s to retain touch id?
I have a broken home button but I would like to keep touch id so I don't want a replacement home button. If I get a original home button off another iphone 6s will i be able to keep touch id?
Thank you for you're help!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
you can your but touch id function wont work why because your original touch id paired with cpu...
if you put another touch id finger print not work
so you not able to use touch id function
you can use for menu button function
Score 2
Comments:
That's what I was wondering. Because I have two original home buttons from apple but one broke so I thought I could change them over. I guess they're locked to the logic tho .
Thanks for everyone's help
by
Add a comment
Doesn't matter if it is original or not, if you replace the home button Touch ID will never work again UNLESS you take it to Apple and say it doesn't work. They will use their magic pairing thingermabobber and it will work again. So yes, it CAN work again, but not without a trip to Apple! :)
Here's the part:
iPhone 6s and 6s Plus Home Button Assembly
Score 1
Add a comment
Hi
Plz Go Thorugh Below Link
https://www.youtube.com/watch?v=Zv1LO9vG...
Hope it Works
Thanks
Varun
Add a comment
Add your answer
Shawn Daw will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 59
