Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 won't turn on after trying to fix camera glass with heat gun
Hey i found a video that said the camera glass can be removed by heating it up from the outside with a heatgun. I did that, the camera glass didn't move at all, and now my phone won't even turn on...
I had the display removed before heating so, it's probably not the display..
Do you guys have any ideas which parts could be bad?
Thanks!
Score 1
Add a comment
Chosen Solution
You could have damaged the screen cables whiles trying to plug it back in. Plug it into your computer with iTunes turned on to see if iTunes will detect it.
You could have blown the backlight circuit, specially if you did not disconnect the battery first and plugged it in last when pulling the screen.
You could have caused long screw damage by putting screws in the wrong holes when reassembling the screen.
Finally, you could have killed the board using too much heat, if the temp of the board went above 190 Celsius.
Whatever the case, you need to have someone with board experience look at it in case it isn't the screen.
I hope you had a back-up of your data too.
Score 4
2 Comments:
Those are good answers. I usually use about 360-380 celcius when doing board repair
by
For most iPhone rework I use 330. Air flow 2/9.
by
Add a comment
Most Helpful Answer
The back camera? Did you apply heat to the back of the phone, with the logic board still in? It's possible you've knocked some of the balls loose on the board. That's what's coming to mind, you'll have to send the phone to a board repair shop
Score 4
3 Comments:
I've always preferred briefs to boxers myself...helps avoid loose (solder) balls on the board. ;>)
by
yes to the back, i mean i realized that it wasn't the best idea when i felt how hot the entire device got, even the battery, but by then it was already too late...... :-/
thanks for the answer!
im gonna check out if makes sense economically to send it in
by
@refectio I figured your hay day being in the 80's you'd have that reaction hahaha
by
Add a comment
Add your answer
Sam Parko will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 266
