I replaced the carburettor and now it won't crank
I bought this scooter and it was running fine first couple days then it started flooding out worse each time I rode it. I took the carburettor off and was going to check the float when I notice the housing on the carburettor where the float is was cracked. I guess the last owner tighten the screw down to much to crack the housing. This gave me reason to buy a new one. I put the new one on and now I can't get it to crank
Add a comment
1 Answer
Most Helpful Answer
Hi,
Here is a link to the service manuals for Jonway cycles. Select your particular engine and download it. Hopefully it will help you solve your problem.
http://www.carlsalter.com/jonway-service...
Score 2
2 Comments:
Thank you this was very helpful but in still having trouble this manual does not show how the fuel lines are run or the vacuum lines
by
Hi, Are the diagrams in this link any good top you?
http://mechanics.stackexchange.com/quest...
by
Add a comment
Add your answer
Jason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 103
