Poor ol laptop, tired ol me, please help.
Turn on to get black screen. Nothing else; no menus, no errors, no text or colors, just black. LEDs work. Tried hard reset few times. Removed battery. Tried holding to power button for 60 seconds still just black. The fan runs fine. No beep codes until I tried pushing f8 immediately upon restart, then I received 4 beeps pause 5 beeps. Also, another 2 beeps code was given after trying the f10 button upon powering up. All beeps were short. No cursor and no mouse. Caps LED doesn't remain on it turns off after a few moments. I don't have another monitor to hook my computer up to unfortunately. I was able to get to the memory modules but have no clue what the heck to even check for reseating them. I'm not super computer savvy, but like to think I'm not a lost cause either. It was working fine yesterday I go to turn it on today and boom, just black. So, if anyone could please help me with what I can do to fix it, from home preferrably, that would be extremely helpful and I would be very appreciative. Thanks in advance. Also, thank you for your time reading this, regardless if you are able to help. Have a great day!
Hi,
Does the laptop stay on if you just start it normally, (I know that there is no display) or does it turn itself off? (You can turn it off by holding the power button until it starts to shut itself down)
What OS is installed?
According to the specs for your laptop it has a HDMI port so you don't need another computer as a monitor, just connect the laptop to a TV with a HDMI input, using an appropriate HDMI cable. Turn on the TV and switch the TV input to the selected HDMI port, then turn on the laptop and see if there is a display.
If there is no display on the external monitor either then most likely there is a problem with either the GPU (graphics Adapter) or the motherboard.
by jayeff
