Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
116 Questions View all
LCD Problem after Touchscreen Replacement. Stripes, Lines
I have fixed an iPad mini 2 wifi model which had broken touchscreen. I have done everything as usual. After assembling the device, an LCD problem occurred. You can see lines, color differences and stripes. These change from app to app. What can be the trigger for this?
I have tested another LCD and it works perfectly. That is, the problem is with the LCD unit. Someone had such a problem? Can you fix it?
Restore and Hard Reset don't fixed my problem.
Add a comment
1 Answer
Chosen Solution
Did you disconnect the battery before removing the LCD? That can cause some problems with the LCD. The other thing to verify is the condition of the connector (both on the flex and on the logic board). If the problem always follows the original LCD and the replacement always works well, then you probably have a partially defective LCD.
Score 2
Comments:
I have to admit that I forgot to disconnect the battery. The connectors look good on the outside. The LCD is the original Apple display. With other original Apple LCD it works. Maybe just a fuse burnt?
by
Add a comment
Add your answer
kamilerdmanski will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 9
All Time: 247
