Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
1362 Questions View all
Bluetooth can't be turn on. No toggle - loading icon instead.
Hey!
I'm recently experiencing an issue with my customers iPhone 6 Plus.
The problem is if you go to Settings -> Bluetooth you can only see the Bluetooth heading and instead of the enable/disable toggle switch there's some kind of 'loading' icon. It just keeps spinning forever.
Already restored it, installed latest firmware through iTunes (both normally and through DFU mode), tried reseting network settings alone - none of these would work.
Any clues?
Score 1
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Chosen Solution
Wifi antennae
iPhone 6 Plus 5GHz Wi-Fi Antenna Replacement
iPhone 6 Plus 5GHz Wi-Fi Antenna Image
Product
$7.99
Score 3
Comments:
Thanks for response imedic! Also thought about it but wifi itself is working fine. Is it possible that only one of these modules is damaged on the antenna part?
by
That is kinda strange, did you recently update iOS? Also try resetting your network settings
by
That's another example of trying to replace the tires when your car won't start.
by
Add a comment
Bluetooth chip problem, replacing the antenna will not help in any way.
Get someone to diagnose and repair the board for you.
Score 1
Add a comment
I have the exact same problem. Did you find any solution?
Add a comment
Add your answer
ddomanski94 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 329
