installed iatkos on mac. wont boot now
I installed iatkos on mt macbook pro thinking it was snow leopard. Now it wont boot, or let me reinstall the original osx cd.
Here is a link for an Apple guide to erase and install your operating system.
I have tried this method already. when I start the macbook holding C, it starts booting from the cd, then tells me "the computer needs to be restarted. hold down the power button". The only way i get it to boot is safe boot, but then I get the message that "osx cannot be installed on this computer". I can access the disk utility, and have erased the HD, but this does not solve the problem.
Thanks for the help Markus. I spent too many hours on this stupid machine, and still does not boot.Got a good bid on ebay(More than I paid), so I think I'll stick to a windows PC, maybe even try the iatkos.
first of all: LOL (sorry, but it's a very lame story)
the iatkos setup doesn't look like the leopard or snow leopard setup
anyway - try rEFIt - i think it's the only way to get you mac up and running again
Thanks Markus. how do I get this into a boot mode from windows xp?
maybe you should try this guide: CLICK. maybe it works also from an usb pendrive (transmac is able to write the dmg file)
I thought you would probably have to step in on this problem. Is the reason you can't properly erase the drive a boot sector modification caused by iatkos? +
Hey Markus. I the program to boot, but I don't really know what I am doing. About the boot sector, does the following look correct to you. I got this info using refit.
Current GPT partition table:
# Start LBA End LBA Type
1 40 409639 EFI System (FAT)
2 409640 488134983 Mac OS X HFS+
Current MBR partition table:
# A Start LBA End LBA Type
1 1 488397167 ee EFI Protective
MBR contents:
Boot Code: Unknown, but bootable
Partition at LBA 40:
Boot Code: None (Non-system disk message)
File System: FAT32
Listed in GPT as partition 1, type EFI System (FAT)
Partition at LBA 409640:
File System: HFS Extended (HFS+)
Listed in GPT as partition 2, type Mac OS X HFS+
good question - i never used refit since i never nuked a macbook with chameleon. maybe you will find something here: CLICK
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,444
