Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3618 Questions View all
iPhone 6 wifi seems very weak?
Using Iphone 6.
For a few days now my wifi seems to be working very poorly. I am only able to connect to my router when I'm next to it! It used to detect tens of different routers in my house but now its down to one or two..
Should I replace my wifi antenna?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Maybe. You also may want to do a force restart first. Maybe even a dfu restore. Instead if jumping in and replacing the antenna. You also may want to try toggling airplane mode, off and on
How to Force Restart an iPhone 6
Plug your device into your computer with a USB cable.
Turn off the device.
Hold the Power button for 3 seconds.
Hold the Home and Power buttons for 10 seconds.
Release the Power button but keep holding the Home button.
More items...
Hmm, kinda surprised they don't have a guide for this. Remove the logic board using this guide, then remove the antennae on the back
iPhone 6 Logic Board Replacement
iPhone 6 Logic Board Antenna Flex Cable
iPhone 6 Logic Board Antenna Flex Cable Image
iPhone 6 Logic Board Image
Guide
Difficulty: Moderate30 minutes - 2 hours
iPhone 6 Image
Guide
Difficulty: Very easy25 - 30 seconds
Score 3
Comments:
Thank you very much for your quick reply! Force restarting didn't seem to work, will try to factory reset tomorrow and if that doesnt work I will replace the antenna. I actually found a link with an antenna for 0.82 dollars!
by
Ha. I've found that cheap parts usually give me more problems than when I started
by
Ooh that's good to know! I will find a better site then;) thank you!
by
Add a comment
Teun if you have dropped your phone recently it will probably end up being the antenna and I agree with @theimedic on staying away from cheap parts. Just some advice if you have never pulled the logic board out follow the guides exactly and keep track of the different screws. Also the antenna is very thin and flimsy so be very easy when removing the old one, I have unfortunately ripped the connector off the board side before, not good! I just replaced one with weak wifi actually the same as you are describing and once I was done it made a huge difference. Good Luck!
Score 2
Comments:
Oh, yeah. @avmech00. I totally forgot. I recommend, if you're not doing this all the time, a plain white piece of paper will do. Organize the screws exactly as you took them out, and return them in same. It could be detrimental to your board!
by
Thanks so much for your replied guys, I love the iFixit mentality and community!!
by
Add a comment
reset your sim card,
Add a comment
Add your answer
Teun Bruijnen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 203
