How to fix when the iPhone say it needs to cool down before you use th
Need an answer!? How to fix it
@joehabablus you do want to check iPhone 5s crashing after battery change by @refectio It will explain to you exactly what to check for.
Reword your question, please.
If you mean, "before you use it", I would let it cool down first and then proceed to check on the battery voltage. (If you don't have a volt meter, have it checked by your closest reputable repair shop)
Make sure it's getting the proper volts as inscribed on the battery.
Also, if you have gotten it wet maybe, there could be standing liquid inside the device causing it to react and overheat the device.
And no, rice will not solve the issue. Haha
Hope some of this helped for you.
Jason
Temperature, iPhone needs to cool down before using. How to fix it
I haven't used my iPhone 5 for almost a year and when I decided to use it, it came on but it said, " Temperature, iPhone needs to cool down before using" and it's not even warm or hot. Does anyone know what I could do to fix it myself at home because all the electronic repair stores here in Belize are closed due to the Covid-19
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 2,168
