Fourth generation of the Toyota Pickup.
32 Questions View all
dome light does not work?
dome light works when passenger door is opened but not when drivers door is opened? checked button it is ok.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
steven white , If passenger door puts the light on and you tested the light button on the drivers door and found it to be good, you will have to trace and check the plug/wires from driver door switch for corrosion, bad grounding or bad/damaged/open wire. Good luck.
Score 2
Add a comment
Add your answer
steven white will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 46
