TV has no sound
Went to sleep Toshiba 32E200U TV had sound. Woke up it has no sound.
What could it be
Update (01/19/2017)
1) Tried shutting things off before as well as checking other channels to make sure it wasn't the channel.
I cannot unplug each cable... because I will never be able to plug them back in where they belong...
haven't taken my TV repair course yet. I did check to see if they were plugged in securely.
2) I just shut down the stip where everything is plugged into figuring that stops the power to them w/o unplugging them individually.
3) Still trying to find the so-called MTS feature... will let you know when I turn TV back on.
Same no sound
3 Comments
@gervblg safest bet is to unplug the set from the strip, not just the power strip.
by oldturkey03
Same as me Toshiba tv and fire stick connected no sound
by shirley Robbins
Toshiba TV same problem as Volume keeps going and coming back only after switching off the TV for at least 10-15 seconds and volume resumes for the next 2-5 minutes or so and keeps repeating.
by Arjun Rathod
