Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3948 Questions View all
white lines about 1 cm long across top of screen after battery replace
just replaced the battery on i phone 6. everything is working but there are lines across the top of the screen about 1 cm long going from left to right. The lines are semi transparent. I've tried re seating the cables and doing a hard reset. Any suggestions will be appreciated!
Comments:
after a few hours, the little lines have vanished and the phone is operating normally. Weird.
by
Add a comment
1 Answer
Chosen Solution
This is common where there's an issue with the digitizer cable. You could try cleaning out the cable and connector socket with 90% isopropyl alcohol. This doesn't sound like you'd have any bent pins, but check for that. It's also possible you've damaged the cable on the display
iPhone 6 Front Panel Assembly Replacement
iPhone 6 LCD Screen and Digitizer
iPhone 6 LCD Screen and Digitizer Image
Product
$69.99
Score 1
Add a comment
Add your answer
Johann Fitzgerald will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 68
