The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Questions View all
Only backlight on startup, after randomly cutting out while powered on
After the screen randomly cut out while powered on, only leaving the backlight on during use, I have not been able to get any picture since. As far as I'm concerned there has been no severe water damage to this computer. However living in a humid environment may be the cause of some corrosion but from the looks of it there is no corrosion on the board.
I've tried (with no luck)
  • SMC Reset
  • NVRAM Reset
  • Tried to boot in safe mode (unsuccessful)
  • Did a full teardown to check for signs of water damage, besides a tiny amount of corrosion no severe water damage was found.
  • Booting up to an external drive with an OS installed
  • Connecting another display
TLDR: The startup sound will play, but only the backlight will turn on, and the caps lock light will not turn on.
Add a comment
1 Answer
My phone come on but can not see the menu button
Add a comment
Add your answer
mac boogs will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 46
