Machine fills up after empty cycle
Zanussi essential 1400
After emptying machine part fills with water and fabric conditioner
Thanks for clarifying the speed of the fill. That really narrows the answers down to just these two:
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the washing machine. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
Cause 2
Low Water Pressure from House Supply
The home water pressure might be too low. The water inlet valve requires at least 20 psi to function properly. Check the water pressure to the valve to determine if it is sufficient.
Here are the valves for the senussi machines : https://shop.ukwhitegoods.co.uk/zanussi-...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 85
2 Comments
Over what period of time does it fill?
by mayer
two days and then an inch in the drum
by kendo551
