Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
258 Questions View all
My digitizer is dimming after I repaired my screen?
After I replaced my glass screen the digitizer has become dim. I can see the apple sign when I turn it on. And when I try to turn it off I can see the X button where you would exit powering off. What do I do?
Comments:
I have to look at the screen in the light. What is the back light? Or where is it.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
How dim is the screen? Make sure the brightness is turned up. Make sure the connector are properly connected. You could try a soft reset. Does the LCD display an image when it goes to the home screen, or do you have to be in light or turn the iPad a certain way to see what's on the display, if that's the case the black light fuse may need to be replaced.
Score 2
Comments:
Cues it's the back light than. Because I have to look in the light to see the screen. Where would the back light be at?
by
Ooh it's the backlight diode filter
by
@theimedic, you should turn that into an answer.
by
Add a comment
Add your answer
Sharla Coleman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 21
