Black out no power no hard drive noise no fan noise , still charging
Power light green is on and charging , no fan running no hardrive noise and fan
Help me
Ihoping not a mobo issue ''
Help me
Hi,
Try a Power reset and see if it works.
Switch off and remove the charger from the laptop if it is connected.
Remove the battery from the laptop.
Press and hold the Power button for 30 seconds and then release the button.
Connect and switch on the charger and then turn on the laptop and see if it starts. (Leave the battery out at this stage).
If the laptop turns on and boots normally, allow it to boot all the way to the Windows desktop, then allow the HDD activity to "settle down" before turning off the laptop in the normal manner.
Once it has completely shutdown, switch off and remove the charger from the laptop.
Re-insert the battery.
Reconnect and switch on the charger and then turn on the laptop.
If the laptop turns on and boots normally, allow it to boot all the way to the Windows desktop, then allow the HDD activity to "settle down".
Check the charge state of the battery. (Taskbar icon perhaps)
If it is charging, allow it to fully charge before switching off the charger.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 77
