2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
120 Questions View all
Which screwdriver do I need?
Hello, i've a MacBook Pro Retina 15" Mid 2014. I need a screwdriver to open the lower body, to remove dust.
Which one should i buy?
Thank you.
Add a comment
1 Answer
Chosen Solution
Most of the IFIXIT guides list the needed tools as well as within the given step what the screw is.
Here's the IFIXIT guide to pop the bottom cover: MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement clearly in this case you're not replacing only cleaning ;-}
As to the needed tools, this is what you'll need for a screwdriver: P5 Pentalobe Screwdriver but if you don't have any tools at all I would recommend getting a kit so you'll be prepared for other repairs. And besides, you should get at least a wrist strap so you don't damage anything internally from ESD (static electricity). I would recommend getting this kit: Classic Pro Tech Toolkit
Score 2
thank you! On the UE store there's this one available --> https://eustore.ifixit.com/en/Tools/Driv...
is it ok?
That will work too.
Add a comment
Add your answer
Alessandro Serena will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 45
