Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
My Replacement Rear Panel doesn't have a Threaded hole.
The hole that holds the screw that holds the GPS antenna in. How can i go about this?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
if you've the skills get out the drill or use a heated needle and make a starter hole which you can then push the screw into using a bit of pressure. It doesn't have to be screwed down. you could try a bit of doublesided tape-or that really sticky glue that can be reused (the type credit cards and stuff are stuck onto paper with when they get sent out?)
Score 1
Add a comment
Add your answer
Michael will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 755
