My Replacement Rear Panel doesn't have a Threaded hole.
The hole that holds the screw that holds the GPS antenna in. How can i go about this?
if you've the skills get out the drill or use a heated needle and make a starter hole which you can then push the screw into using a bit of pressure. It doesn't have to be screwed down. you could try a bit of doublesided tape-or that really sticky glue that can be reused (the type credit cards and stuff are stuck onto paper with when they get sent out?)
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 757
