Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
No display, no vibration or noises.
So some odd reason my iPhone 5s seems to not work. The vibration, display do not work. I know the phone works because when I connect it to iTunes it works and it shows my device. There is also NO noise when plugging it to a wall to charge my device, not even a vibration. Any advice to resolve this problem? Just purchased and replaced my LCD and I'm sure that I've followed the instructions correctly.
1 Comment
press and hold home button and power button and see
by
Add a comment
1 Answer
Chosen Solution
Hello Demetrios, so sorry to hear about your problem. What i would try to do if i was you, is unplug the battery, and test your old LCD back on the phone again. Plug the battery back in and if it comes on, then that means the new LCD is not compatible... you might have already tried to do that, and if you have, then it is possible your phone has got some motherboard issues. in the process of changing the LCD in the first place, hopefully you unplugged the battery prior to unplugging anything else. If you did not unplug the battery first, or at all, then it is a good possibility the motherboard got shocked. That could be a possibility considering that itunes picks up the device, yet it shows nothing.
I hope this was of some help, if you have any questions about what i have said, then please ask. Or if you have anymore more details about the situation, i can try to help out the best i can. Thanks for your time, and have a good day.
Score 1
Add a comment
Add your answer
Demetrios will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 54
