Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Screen is really light, can hardly see the images
My iphone 3g screen is very light and i can hardly see the images. I iphones and tried putting a new lcd and touch panel off another 3g i have,and the display is still very dim, so I believe there is something wrong with the phone its self.. any suggestions?
Score -1
Add a comment
Chosen Solution
it sounds like the backlight-have a search on here- you can try replacing/cleaning connector 1 (or get an iphone repair shop to do it for you as it's very difficult and involves micro soldering) or there are some links to replacing backlight coil (uses a blackberry or nokia component) and placing wire from coil to LCD
Score 1
Add a comment
I can hardly see mine its a Iphone 3 I turned it on it was bright but the it went to you could hardly see it. what do I do?
1 Comment:
did you read the above answer and did you give it a try?
by
Add a comment
Add your answer
Mat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,703
