Holy Stone drone will not start! Please help :(
I have a HS 110 Holy Stone drone. I've had it for about a month and have enjoyed it so much! I've flown with no problems at all except and occasional minor crash, nothing major at all. I was flying it the other day and everything was fine, no problems at all. The battery got low in the drone so I changed the battery in it and paired it with the controller but I noticed it wouldn't let me calibrate it. When I tried to take off it flew maybe 7 feet in the air and landed on it's own and wouldn't take off again. I thought maybe it was a dead battery so I put another in, and put fresh batteries in the controller. I got the same results this time, seemed to pair with the controller, wouldn't let me calibrate it but this time the rotors wouldn't turn and it just sat there with the lights blinking.
Can anyone help me? I'm at a loss ...
Score 3
2 Comments
Hi I have a holy stone drone but it’s not starting I change the battery still no use
by
A friend of mine has the HS-720, turns on but turn off 2 seconds later. Will appreciate any help
by
Add a comment
Most Helpful Answer
Hello,
I also had issues with ProMark p70 drone calibration. But the problem was I calibrated it close to the garage doors, and it didn’t make any progress. So the issue wasn’t gps.
A couple of useful guides for your model:
Holy Stone HS100 Compass Calibration YouTube Vid
Calibrate the drone’s compass each time that you fly an article by April Klazema
Score 1
Add a comment
Mine did the same thing I figured out what was wrong it was in GPS mode hold the compass button for 3 sec and it will go out of it.
1 Comment:
Where is this compass button located? Same issue on the hs200
by
Add a comment
My ha 165 holy stone drone work fine yesterday but now when I try to take off all it does is blinking it’s lights at the same time not fast will unlock motors but won’t take off
1 Comment:
Did you find the issue? My new one is doing this
by
Add a comment
I think I know the issue I had this on mine. You need to make sure it is not in GPS mode. It starts in GPS mode by default for some reason but it won’t take off in that mode.
Add a comment
So I got a hs161 flew it then recharged the battery after first flight. Full charged now but drone won't turn on
1 Comment:
Same as above make sure it is not in go’s flight mode.
by
Add a comment
Hi my holy stone 720 keeps turning off I got for my brithday and when I got it out the box’s it dose not stay on so that means I can’t set it up
Help
Add a comment
My drone Holy stone hs100 battery broken fly up drop
Update (09/01/2022)
1 Comment:
by
Add a comment
I have a holy stone hs110g, it worked fine but now it wants to go in its own direction after a while.
Add a comment
Holy Stone drones are so unpredictable and temperamental . I had 2 from them the best being a 175d. The camera stopped working after 3 flights and connecting to GPS was a joke. Nearly lost £190 due to this issue. I had enough and bought a DJI mini 2. Wow what a difference. IMO holy stone are not worth the money. Don’t buy one and save up for a DJI
Add a comment
my name is jim and i have been flying the hs700e for about 2 years now and never had a problem other than a few scrapes and bruises,if you know what i mean.i recently replaced my original hs700e with a brand new one with the same expectations.for the first 5 or 56 flights no problems,but out of the blue the 7th flight i could not get the drone and the wifi to sync i have tried several differert procedures buit nothing seemed to get it to go.so i started reading deeply about battery issuses and how important it is to not put hot batteries in a freshly lamded drone and to make sure when d
charging that they get the max cgarge possible and whala it fixed my issues and took my time instead of rushing like i usualy do. hope that helps you out good luck and let me know what ther esults are
Add a comment
Add your answer
David Watlington will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 115
All Time: 18,252
