Repair information and guides for MacBook Pro models with 13" displays.
9729 Questions View all
Question Closed
water went inside lcd
hi,
water slipt on mac went inside lcd,clearly water is visible in between two screens.AND my battery also not detecting..
i cleaned everything inside but no luck battery wont work and by ifixit suggestion all water indicating white spots not changed in to pink..
can i apply for warranty??
tanx .......
Score -1
Add a comment
Most Helpful Answer
If all signs of water damage are not present and the white spots have not turned pink, bring it to an Apple Genius bar and see what they say. Don't say that you dropped it in water, but that the battery stopped working.
If your MBP is out of warranty, you're out of luck. You will have to pay Apple to fix it or find someone else to do it if you've tried guides on ifixit.
Good luck!
~dan
Score 1
Add a comment
I have the same problem, Im out of warranty too, do you think it will be expensive to repare it or not
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 542
