Battery is not charging, green light, can't reset SMC.
1. This machine runs perfectly fine with charged battery inside (i.e. fan speeds normal and all is well). However, the battery will continue to drain as the green light on charger stays on and computer indicates not charging.
2. Machine also runs without battery (using special power-up technique), but the fan goes at full speed the entire time.
I have installed FanControl software to try and delegate fan speeds, but without battery the min-max fan speeds say 0-0 even while fan is blazing. FanControl runs properly when charged battery is in the machine.
I have disassembled the machine completely to look for any hardware issues, but everything appears fine.
I have tried SMC reset, but light does not indicate that this was successful and battery still won't charge.
Battery Information:
Model Information:
Serial Number: 9G9440GNM8VNC
Manufacturer: DP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 3
Hardware Revision: 2
Cell Revision: 100
Charge Information:
Charge Remaining (mAh): 760
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 4670
Health Information:
Cycle Count: 445
Condition: Normal
Battery Installed: Yes
Amperage (mA): -1797
Voltage (mV): 10637
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
Hibernate Mode: 3
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 0
Battery Power:
Display Sleep Timer (Minutes): 2
Hibernate Mode: 3
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 0
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x00ba
Serial Number: 0x00b0f2d7
Charging: No
2 Comments
Can you give us the exact model of your system. Apple has quite a few different models. From the About This Mac copy the system serial number and paste it into here: EveryMac - Lookup it will show you your system. Paste the URL here for us to see as well.
by Dan
Macbook Pro 8,1 (Early 2011)
by Benjamin Smith
