Why won't my brake lights work
I have all lights working Four way flashers, tail lights, turn signals but no brake lights. I have replaced the fuse, the brake light switch, and the bulbs, still nothing what could be the problem?
Score 1
Add a comment
Chosen Solution
Do a continuity test on the wire from the brake light switch on the brake pedal to the brake light socket in the rear of the car . There's probably a short in the wire . Hope this helps
Score 2
Add a comment
I figured it out. It was the trailer light wiring harness. The previous owner tried rigging up a homemade wiring harness. Smh, but I just unhooked that one and did it the right way. Now all of the lightsame work. Thanks for the help
Score 1
Add a comment
stoplights go thru the turn signal switch..even tho turn signals work contacts for brake lights may be corrodded
Add a comment
Add your answer
Mark Anthony Branch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 76
All Time: 12,367
