2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
116 Questions View all
Can I swap M.2 SSD from 2014 MacBook Pro to 2014 MacBook Air?
Hi - I'm trying to recover data from a dead 2014 MacBook Pro (due to liquid damage) and was wondering if the M.2 SSD in this laptop would work inside a 2014 MacBook Air. I'd be looking just to boot off of it from the Air so I can back up the data, then go back to the Air's original SSD.
Will I run into any problems by doing this? Thanks!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Yes, the 2014 SSD in the Macbook Pro Retina will work in the 2014 Macbook Air. The original SSDs are not M.2, so if there is an M.2 SSD in your original, you need to use an adapter.
Score 2
Add a comment
Add your answer
Nerdly McSquib will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 48
