Do you know when this problem began? Try a System Restore to a point in time BEFORE the problem began. Be sure to check the box to show more than 5 days of restore points. If the first attempt fails, then try an earlier point or two. NOTE: You will have to re-install any software and updates you installed between now and the restore point, but you can use Windows Update for the updates. Use the recovery disk if the system prompt doesn’t work.
If the System Restore doesn't work, do a Startup Repair by booting to the genuine Windows Vista Installation Disk (or one you can borrow from ANYONE) or from a Recovery Disk. To boot to the CD you may need to change the BIOS to make the CD-drive first in the boot sequence. To do that, wait for the screen that tells you the F key to push to access the boot menu or boot setup. Push it quickly. Make the changes, save your work, and exit. Put the CD in the drive and reboot. When prompted, push any key to boot from the CD. I know you tried this from the system but it might work better if done from the disk.
If you don't have either disk, you can make a bootable Recovery Disk along with burning software and, of course, a blank CD.
If that doesn't work, try to boot into safe mode (repeatedly click the F8 key while booting and go to safe mode with networking – or do so from the command prompt on the disk). Then let's check some of your system files:
Go to Start / All Programs / Accessories / Command prompt and right click on command prompt and click run as Administrator (you can skip this step if using the disk).
If using the disk, change directories to C:\Windows\System32. Type sfc /scannow and enter and let it run. It will scan and try to fix some of your system files. Hopefully it will complete with no corruption it could not repair. Try to post any corrupted files here so we can see if they can be repaired with good copies from the installation disk (unless there are too many).
While in Command Prompt, type chkdsk /f /r and enter and let it run. You may need to reboot if it schedules itself to run at the next startup. It will scan and try to fix any corruption or bad sectors on your hard drive and mostly remove that as a potential cause.
If that doesn't work, then please post any repeating error messages from the Event Viewer concerning startup (Start / Control Panel / Administrative Tools / Event Viewer – or typing eventvwr from the command prompt).
It may be that your boot information is missing or corrupt on the hard drive (or there is another problem with your hard drive). That's what the error message suggests. We'll have to try to repair that if we can. You will need a Vista Installation Disk to do this process (see below if you don't have one and can't borrow one from ANYONE):
· To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe, and then press ENTER.
Note If rebuilding the BCD does not resolve the startup issue, you can export and delete the BCD, and then run this option again. By doing this, you make sure that the BCD is completely rebuilt. To do this, type the following commands at the Windows RE command prompt:
· bcdedit /export C:\BCD_Backup
· c:
· cd boot
· attrib bcd -s -h -r
· ren c:\boot\bcd bcd.old
· bootrec /RebuildBcd
18 Comments
Windows 7, 8.1, or 10?
by S W
Hi,
Can you get into BIOS to change the boot order to ensure that you are booting from the ODD drive?
Have you disabled UEFI and enabled Legacy/CSM to see if you can then boot from the disc?
http://www.top-password.com/knowledge/di...
by jayeff
This is a window 7
by Bill Light
It doesn't give me the option, but when I pressed F2, and all it shows is this:
CMOS Setup Utility - Copyright (C)
> System Info
> Standard CMOS Features
>Advanced BIOS Features
>Advanced Chipset Features
>Boot Device Configuration.
by Bill Light
Hi, Click on boot device configuration and select the cd drive as the first boot option, ahead of the HDD, save and restart the PC with the installation disc in the drive, then try the repair option from the disc..
by jayeff
Show 13 more comments
