The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
100 Questions View all
Why won't my tablet charge completely
why won't my tablet charge completely after 12 hours of charging?
Score 1
1 Comment
You'll need to give some more info.
by
Add a comment
1 Answer
Most Helpful Answer
hdjuback , Try to charge your device again, making sure the charger is plugged snugly in charge port. Verify charger is in deed working( try it in another tablet if able), charge port could be loose/damaged, battery connection or charge port connection may need cleaned and reseated, battery could be defective.
If still under warranty return device for repair/replacement/refund. If not you may want to open the device and check the connections(charge port/battery) and clean them with Qtip/soft bristle tooth brush dampened with 90% isopropyl alcohol and reassemble and try. Below are links to a couple guides to show how to open device to access/change charge port/battery. Some replacement parts are available for the Galaxy Tabs at the iFixit store, last link if needed. Good luck.
Galaxy Tab S 10.5 Charge port Replacement
Galaxy Tab S 10.5 Battery Replacement
[[ invalid parts link ]]
Galaxy Tab S 10.5 Battery Image
Guide
Difficulty:
Moderate
15 - 45 minutes
Galaxy Tab S 10.5 Charge port Image
Guide
Difficulty:
Easy
15 minutes
Score 3
Add a comment
Add your answer
hdjuback will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,240
